Machine Vision
Converting RGB image to a useable format
I'm taking a live image from an RGB Sony camera and what to simply 'invert' the image palette so the colors are reveresed. I get the good ole' invalid image type error. I've tried the 'convert 16-bit to 8-bit image - but it too. Gives me the 'invalid image type' error.
I am doing a rather intense vision application  and would like to see if I can configure the camera in MAX to give a color image in a format that I can use the invert function without doing the rather math intensive  convert.
Why is this such a pain? Why dosen't the canned pixel and color pane manipulation routines NOT work in a standard out-of-the-box RGB camera?
Regards
(3,211 Views)
Hi Alias,
In Vision, there is an imaqInverse function which outputs the inverse of an image.  I am assuming this is what you are using, because it only supports grayscale images and will give the 'invalid image type' error if a color image is used.  You could use the Vision function Extract Color Planes which will give numeric values for R, G, and B.  You can then perform simple math (255-x) to get the inverse and then use imaqReplaceColorPlanes to recompile the image.
Ryan M.
(3,192 Views)
