10-05-2005 08:43 AM
10-05-2005
10:54 AM
- last edited on
07-08-2025
03:55 PM
by
Content Cleaner
Kevin,
did you already test it with the NI-Example "Grab and Attributes Setup.vi"? You should find it on you PC at \National Instruments\Examples\Imaq\Imaq1394 examples.llb.
This example works very well.
You could download the latest driver version at http://digital.ni.com/softlib.nsf/websearch/09F9367451DB38278625702D00673856?opendocument&node=132060_US
Steffen Hoog
10-27-2005 04:01 PM
Thanks Steffen:
The problem is that when I try to use a triggered sequence
10-27-2005 04:01 PM
Thanks Steffen:
The problem is that when I try to use a triggered sequence of
10-27-2005 04:01 PM
Thanks Steffen:
The problem is that when I try to use a triggered sequence of images
10-27-2005 04:05 PM
10-28-2005 11:26 AM
A sequence acquisition does not allow for a delay between images. It will snap all 11 images without any delays. I think the only way to do what you want is to use a sequence for 10 images, then snap the last image separately after adjusting the parameters.
Bruce
10-28-2005 11:52 AM
10-28-2005 12:02 PM
11-04-2005 08:18 AM
