Machine Vision
Converting images from a Matrox frame grabber to LV?
How can I convert an image captured with ActiveMIL Lite from a Matrox frame grabber to an IMAQ Vision image?
I grab the image in LV using the ActiveMIL Lite functions. After that I will analyse the image using IMAQ Vision. So I have to convert the Matrox image to a LabView Image.
Thanks for help
(3,365 Views)
Uli,
I believe Graftek Imaging has LV drivers for Matrox frame grabbers. You can call Robert Eastlund at (800) 441-2118 and he will be able to help you.
Bruce
Bruce Ammons
Ammons Engineering
(3,365 Views)
