Machine Vision
Coordinate System, Measurements parallel to coordinate axis
I want to make measurements in a dynamic coordinate system. But by coding my application I learned that there is no documenation how the coordinate system is intended to work. The online help topics aren´t very useful. For instance there is no description how the axis reference parameter should work and so on.
Another problem where I couldn´t find proper documentation is when you want to make mesurements within a coordinate system e. g. want the distance between two points measured parallel to the x axis of my coordinate system.
If anyone could give me hint where I can find some information on my problem, it would be greatly apreciated.
Peter
(3,096 Views)
Hi Peter,
Could you be more specific on your question...
It would be nice if you take the time to rate this answer
http://www.machinevision.ch
(3,084 Views)
