Machine Vision
1D arrays to excel sheet
I am having 3 1-D arrays from 3 different connector and want to arrange the three 1D arrays next to each other in excel sheet. Any suggestions.
(3,331 Views)
In order to save three columns into a spreadsheet file, I would recommend using two VIs that come in LabVIEW.
1) Create a 2 dimensional array by using build array and wiring in your three inputs. The "Build Array" Can be found under the 'Array' sub palette.
2) After creating a 2 dimensional array, you can write this to a spreadsheet file using the "Write to Spreadsheet file" VI. This VI can be found on the FILE I/O palette.
Additionally, National Instruments has a large amount of example programs that might be helpful. Here's a link to an example that might be close to your application: Saving to a Spreadsheet File
Hope this helps,
Robert Manion
Applications Engineering
(3,321 Views)
One minor additional suggestion: You may need to use an array transpose on the 2D array before writing it to a spreadsheet file.
Bruce
Bruce Ammons
Ammons Engineering
(3,316 Views)
Thanks!
(3,311 Views)
