Machine Vision
Typedef Error when compiling niScope for DLL using CVI
I am getting the following error when trying to compile a DLL for the NI 5122 digitizer using CVI:
Error creating type library:
All structs, unions, and enums required by exported functions must be typedefs in order to create a type library. The struct/union/enum "niScope_wfmInfo" does not use such a typedef.
I have created a variable and "typedefed" it as niScope_wfmInfo to try and get rid of this error. This did not work. I have tried making several other changes. Some have eliminated the error but created problems with the DLL.
Has anyone had a similar error to this? If so, how did you get around it?
Heather
(3,350 Views)
Sorry, I meant this post for the Highspeed Digitizer discussion board.
(3,343 Views)
Hi Heather,
I haven't seen an error like this before. Is this a custom program that you created or is it an example program? If it is a custom program, do you get this same error when trying to create a DLL out of an example program? The example programs are located in C:\Program Files\National Instruments\CVI70\samples\niScope and I would try making a DLL out of one of the simple examples such as "Getting Started". Let me know if this works.
Thanks!
Erick D
NI Applications Engineer
(3,334 Views)
