Machine Vision
Correct image skew
What tools are offered in NI Vision to correct image skew?  Example image attached and it should be square.
Thanks in advance!
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(5,347 Views)
Accepted by mfitzsimons
Hi Matthew,
There are a couple of different options that can correct image skew. If we are capturing an image from a camera, then the best way would to correct for skew (and other distortions) would be to first calibrate the image using a grid and then correct the image (Image Calibration and Image Correction steps in Vision Assistant or the calibration palette in the VDM; see this link).
If we just want to de-skew an image without using the calibration steps, then it requires a bit of coding. I have attached an example that one of my colleagues is working on for a Community Example (it just has not been posted yet). Hopefully it will prove useful.
Bill E. | Applications Engineer | National Instruments
(5,316 Views)
Took a few tries but got it to work.  Can you give me some background on the formula used to transform the image?  I was really surprised that no one has posted a question on this.  Seems it would be a common issue.
Works well and many thanks!
Matthew Fitzsimons
(5,313 Views)
I do not think it is a “named” algorithm, but what it is doing is using similar triangles to skew the image row-by-row. It gets the skew (user input) and the image height to generate a new array. The original image is then shifted based on a right triangle using the skew and the image height. Note: there may be more efficient ways of accomplishing this.
(5,291 Views)
It works just fine so it is a keeper.  I put a timer on it and it is less than 1 millisecond to process.  If the imge was substantiall larger then I may have to look for alternatie methods.
Thanks!
Matthew Fitzsimons
(5,289 Views)
Here is the link to the Community Example, as it is live now, for future reference.
(5,284 Views)
