Hi iamcoconut,
You can use the pattern matching functions in IMAQ Vision to search for complex images, such as a set of eyes, etc. However, if you are going to have images of people from different angles, the best method to find the people is to use a Static Background type analysis. This analysis takes an image of the background without people in it and then acquires an image of the same background with people in it. Performing a simple subtract and then separating the images, removing particles, etc. isolates your people so that they may be "counted."
Matthew Smith
Applications Engineering
