Machine Vision
Crater detection (image analysis of planetary surfaces)
Hello, I am attempting to design a LabVIEW program that will detect craters on a planetary surface. Background: since no algorithim has been made yet, people wanting to do a planatary survey are forced to use a program called JMARS to manually count the craters on the surface. I have used this program to do surveys on a planetary body and it is rather time-consuming, hence the desire to automate the process. My hope is to develop a crude version of this to detect the craters in a sample image of a planet and overlay ovals on the correct surface. I have been working out ways to do this for some time, and I have only come up with a crude and inaccurate method. In my attached program I have used a detect shape function from the vision toolkit in labview. The circle coordinates are sent out to overlay ovals on the image. I have used a simple convolution filter to enhance the edges.
Please let me know if you have any suggestions regarding this program. I only have about a week and a half to finish this otherwise I will have to abandon it for a different project (this is my project idea for a class).
Attached is my program and a sample image that I am working on.
(4,303 Views)
This sounds like an interesting project!  And your image analysis techniques seem pretty solid as well.  What problems are you having at this point?
Cody A.
(4,281 Views)
