Machine Vision
Create imageControl property subvi
How to create a subvi for this? I pressed "Creat SubVI" in "Edit" but nothing happened.
Message 1 of 11
(5,493 Views)
You have to select the region of block diagram which you want to convert to Sub VI and then press Create SubVI in Edit Menu.
For more on how to create SubVI: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YK4VCAW&l=en-US
uday
Message 2 of 11
(5,467 Views)
I clicked the property node Zoom X and clicked Create SubVI, nothing happened.
Message 3 of 11
(5,451 Views)
Can u give me an example of a subvi using an imagecontrol as input and output its zoomX?
Message 4 of 11
(5,450 Views)
send your code I make it sub vi for you friend
Message 5 of 11
(5,448 Views)
Message 6 of 11
(5,445 Views)
could you send your vi in lower version?
Message 7 of 11
(5,443 Views)
Message 8 of 11
(5,442 Views)
Accepted by topic author tomsze
hope it could help you to solve your problem
Message 9 of 11
(5,439 Views)
this method.pnguse this sub vi with this method
Message 10 of 11
(5,437 Views)
