Machine Vision
DFT not Displaying Well using Mathscript with IMAQ
I am using Mathscript to generate a rectangular shape and finding the DFT. The result is been displayed on IMAQ.
The image generation worked fine, but the DFT display is not showing properly, I have to look very closely to see a faint picture. However the same code on MATLAB gives me the display very sharply. Even when I multiplied the final display output i.e by say 30, it shows the image, but not very well, for instance , I could not see the sinc like shape.
I have attached the VI in version 8,5 and 8.0, and also the correct picture I am suppose to get in .jpg.
Thank you
(3,522 Views)
The image you created are U8 grayscale  images (default) , while you should use SGL grayscale. Right click the Image Type input of IMAQ create and add a constant here. Select GrayScale (SGL). Then connect your array to the Image Pixels (Float) input to IMAQ ArrayToImage.
Chilly Charly    (aka CC)
(3,513 Views)
You could get a similar result still working with U8 values, but using the full dynamic range of the image : find the highest value in the array (HAV) and use it to define a good multiplier (= 255/HAV). Here I find 255/5.8 = 44.
Higher than 30 😉
(3,511 Views)
