08-25-2008 08:07 AM
I want to apply the color threshold function of NI-Vision in HSL mode.
How can I convert a UVYV image to a HSL image? Would this conversion be faster then a RGB-to-HSL conversion?
08-27-2008 04:35 AM
Dear Andrea,
I understand you want to switch from somekind of colormap called UVYV to HSL ? Unfortunately I don't know how this UVYV colormap works.
I do suspect UVYV is not supported by our vision module, searching "uvyv" in the Vision assistant help I find nothing, while I do find useful funcions for RGB and HSL.
I searched also in Wikipedia but I didn't find UVYV connected to RGB or HSL.
If you have a mathematical description of UVYV likely you can extract the transformation to and from HSL and then wirite the associated code.
Best Regards.
08-28-2008 01:45 AM
Dear Jon,
thank you for your reply.
I have found the description of the UYVY in http://www.fourcc.org/yuv.php#UYVY (it is similar to the UVY format).
I am interested in this argument because I am considering the acquisition of a TheImagingSource firewire-camera, that use the UYVY image format. I saw that these kind of cameras are supported by the NI-firewire-driver. I wonder about the actual image format of the images acquired by this camera-driver set and passed to other Vision VI.
09-02-2008
05:11 AM
- last edited on
07-01-2024
03:00 PM
by
Content Cleaner
HI Andrea,
two points
1-If you can connect your Firewire Camera to the PC and see a meaningful image/video in MAX ( measurement and automation explorer) you can use the camera successflully also with LabVIEW or any other Development Environment supported by the Vision Module.
2-If you are interested in recording ad playing AVI files I strongly suggest you searching for AVI in our developer zone .
For instance I was able to find these documents:
Also this document may be useful
Streaming Images to Disk with NI Vision
Have a good Day
