Machine Vision
DMA Error in Acquisition of Image from 1473R
Hiii...
I am using Frame Grabber NI PCIe-1473R to acquire images from a dragster camera over CamLink interface. I am using “1-Tap 10-Bit Camera with Frame Trigger” example code to acquire images. When I am running the above example code to acquire the images sometimes I am getting blurred images & most of the times I am getting timeout error for DMA FIFO. I have not made any changes in the code.
I am attaching the snapshots of errors & the camera file (for Awaiba Dragster 2x 2k_9_8_14). Please have a look on the scenario & suggest changes to acquire the images properly.
(5,329 Views)
Please suggest me any document or tutorial for programming & configuration of other paramters of NI PCIe-1473R
(5,327 Views)
Glad to see there is also someone else who bought the 1473R
I am using it to get pictures out of a optronic CL600 camlink camera.  In labview 2014. At 10Tap 8 bits.
I started out from one of the 4 examples provided for FPGA frame grabbers. You can have the newest 23MB zipped version of my project folder. I hope it helps.
If you get fifo timeout it can be because:
  • you are not reading out the fifo fast enough,
  • the FIFO  is not deep enough on the FPGA side of the DMA channel
  • the FIFO is not deep enough on the HOST side of the DMA channel. You can set the max number of elements in that part of the FIFO with a property node to an extreme value.
(4,201 Views)
My problem is solved..
(4,183 Views)
