Machine Vision
Is this normal 32-bit image converted to 8-bit
Hello
I try check color and luminance each symbol in ma image which is 32-bit when loaded.
I want to have as much as possible data ( precise)
I use IMAQ Count Objects and use it to know how much particels i have, then i take this data and in loop want mesure RGB and Luminance for each particle, but when i  pass image to loop is automaticly converted to 8-Bit why???????
(3,896 Views)
Hello Yetiorg!
Does your problem still presist? Are you trying to do this in LabView? Could you attach your code, so I can check it?
db
(3,817 Views)
