Machine Vision
DP70 microscope camera driver
I encountered an image acquisition problem with DP70 microscope camera. I am trying to access DP 70 (attached to Olympus IX51 microscope) to get the image under LabView and analyze the average intensity of the interested area. However, it seems that NI do not provide driver for DP 70.
Could you help me on this issue? Anyone came across the same problem before?
Thanks a lot!
Lingling
(4,043 Views)
1. Inspecting the camera what type of interface it use, and use NI frame grabber to interface it with LabVIEW, http://sine.ni.com/np/app/main/p/bot/no/ap/vision/lang/en/pg/1/sn/n17:vision,n21:11600,n24:PCI/.
2. If you don't wish to invest on another frame grabber, checking with Olympus whether they can provide instrument driver/API for this camera. An instrument driver usually provide by instrument manufacturer.
(4,025 Views)
