Machine Vision
Connecting Sub vis and Image
I'm trying to connect these two sub vis to my main vi, but when it is connected the main vi doesnt work properly--only the first sub vi work but the second sub vi and the main loop dont work. I really appreciate it if someone can take a look at my connections.
Please review the attched files: If alignment (main vi), untitled111 (subvi) and Grab and Basic... (second sub vi).
The first sub vi defines  ROI and the other camera attributes.
Thank you,
(3,491 Views)
Accepted by topic author simply_me
Never mind, I've solved it and placed the sub vis in the main loop 🙂
(3,485 Views)
Glad and that is exactly what I suggested in the other thread as well.!!!
(3,475 Views)
I think my happiness was a little premature since I still have problem maintainning the image size in the loop since it initializes every time....
(3,460 Views)
