Machine Vision
Connecting Sub vis and Image
I'm trying to connect these two sub vis to my main vi, but when it is connected the main vi doesnt work properly--only the first sub vi work but the second sub vi and the main loop dont work. I really appreciate it if someone can take a look at my connections.
Please review the attched files: If alignment (main vi), untitled111 (subvi) and Grab and Basic... (second sub vi).
The first sub vi defines  ROI and the other camera attributes.
Thank you,
(3,511 Views)
Accepted by simply_me
Never mind, I've solved it and placed the sub vis in the main loop 🙂
(3,505 Views)
Glad and that is exactly what I suggested in the other thread as well.!!!
(3,495 Views)
I think my happiness was a little premature since I still have problem maintainning the image size in the loop since it initializes every time....
(3,480 Views)
