Machine Vision
Detect Crack on Steel Pipe Using NI Vision Assitant
To all,
I would like to use NI Vision Assitant  with USB camera to detect crack on steel pipe.
I can find cracks using NI vision assitan. My question is: can use USB camera/webcam to detect crack via live image?
I am new to this software, so please help me.
Info:
Lab View 8.5
NI VISION Assitant 2009 triall
Automatic and Development Software
NI IMAQ ( to connect USB webcam/camera)
Please tell me whether i have enough software to do the task.
thank
(6,587 Views)
Vision assistant is just to check the steps before you start wiring the values in labVIEW. You can detect the cracks using vision assistant but for building it into an application you require labVIEW. You should also have vision development module which helps you with image processing functions.
Can you post a few images so that we can work on them?
(6,567 Views)
Dear Muks,
I am sorry for late responding. I am including some image as well as screen shot of my simple project. Thus, instead of detecting cracks on the pipe, I just want to detect the circles on a product. ( sample picture). However, i ran into some problems and honestly, i just don;t know how to solve it.
Please take a look at the screenshot and guide me. I would love to learn this solfware but I just donl;t know where to start.
Purpose: To detect cirlces on at a part via live image. .
thank you very much
Notes: screeshot number 2. My NI Vision Asssitant cannot recognize my webcam.
I have Pixxo USB Webcam, AW-M2130
(6,525 Views)
I am again stressing the same point. YOu cannot build a application using vision assistant. You can use a vision builder instead. And for detecting the cracks can you post a few sample images?
(6,513 Views)
Hi.
I would like to ask on how to use the LabVIEW application to detect a crack on a boiler header.
Could you help me and give some guides since I am a new to this software.
Thank you.
(5,402 Views)
Hello Nadiah,
Typically, it is a better idea to create a new thread for a new question instead of posting on a thread that is several years old.  I noticed that you already did just that, so I would simply like to point any other curious forum-goers to the thread devoted to your question:
http://forums.ni.com/t5/Machine-Vision/detect-a-crack-on-boiler-headers/m-p/2298572
Good luck implementing your vision application.
Patrick
CLA
(5,385 Views)
