Machine Vision
Detect object and save object's image
I am trying to detect object and save image. However, the programming sometime can do as request and sometimes cannot. Do anyone know how to ensure this programming is stable? Attached is my programming. It using pixels to detect the object when it arrive at center.
Message 1 of 13
(6,473 Views)
Alas I am still stuck with 8.0. can you post a screen shot too?
Message 2 of 13
(6,466 Views)
attached as request
Message 3 of 13
(6,447 Views)
Also post an image so that I can work on that in parallel.
Message 4 of 13
(6,441 Views)
AS mentioned above attach an image so that i can work on that.
Message 5 of 13
(6,439 Views)
The conveyer background is black in color..it is moving but required to save the image when the object pass the center of the camera as in attach's image..so how to implement the coding 'subtract pixel value = 0' or any idea...?
Message 6 of 13
(6,428 Views)
I fell you are trying to complicate the processing. What do you get if you are going to eliminate the zeros? replace it with what? Try the attached vi. Works for both the objects with the same threshold value.
Message 7 of 13
(6,426 Views)
And then use an imaq extract like this
Message 8 of 13
(6,423 Views)
Hi Citrusgal, could you tell me what kind of camera are you using?  Thank you.
Impossible is nothing
Message 9 of 13
(6,341 Views)
Basler..firewire camera.
Message 10 of 13
(6,336 Views)
