Machine Vision
Devices and Interfaces cause MAX crash
MAX version 4.6.1f0, Windows XP (SP3)
I am trying to add a GigE camera, but whenever I open MAX and try to expand the Devices and Interfaces tree, MAX crashes.
I have attached the error log.  Any suggestions?
Similar to this issue:  http://forums.ni.com/t5/Machine-Vision/After-a-system-crash-MAX-hangs-whenever-the-devices-part-of-t...
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 1 of 13
(6,252 Views)
I tried to fix the MAX database as described here, http://digital.ni.com/public.nsf/websearch/86256F0E001DA9FF86256FFD005B827C?OpenDocument
Unfortunately, this did not fix the problem.
Message 2 of 13
(6,246 Views)
Hello vt92,
Does MAX only crash when you have the camera installed?  Does it work well without the camera?
Lynn
Senior Systems Engineer
Message 3 of 13
(6,219 Views)
MAX crashes regardless if the camera is connected or not.
@Sarci1 wrote:
Hello vt92,
Lynn
Message 4 of 13
(6,217 Views)
Hey,
I would follow What is the Process for Removing MAX Database Corruption? If you get stuck at a step, try completing the steps in Window Safe Mode.  Also, have you tried installing the latest version of the NI-DAQmx 9.2.3 driver?  This will reinstall MAX.
Lynn
Message 5 of 13
(6,189 Views)
I'm having trouble downloading NI-DAQ.  I've tried the NI downloader and the manual download, but windows reports the file as corrupt or invalid.  It may be a problem with the firewall here at work.
Message 6 of 13
(6,126 Views)
Hi vt92,
It definitely sounds like a firewall issue.  You may have to go through your IT department to see if they can allow access.  If you are unable to do this, please contact us and we can have a copy of the driver mailed to you.
Justin D.
Message 7 of 13
(6,107 Views)
I installed NI-DAQ 9.2.3 (MAX version 4.7.7f0).  MAX still crashes.
Any further suggestions?
Message 8 of 13
(5,951 Views)
Log file attached.
Message 9 of 13
(5,950 Views)
Hi vt92,
Have you also gone through the process for removing MAX database corruption?
Lynn
Message 10 of 13
(5,937 Views)
