Machine Vision
Difficulty with the Vision Assistant 2009
Hello.  When I try to run the Vision Assistant it says my screen resolution is wrong and after I click o.k. it just closes.  My screen resolution is 1920x1080, so it should be fine?  I am using Windows 7 64 bit version.  I asked NI support and they just sent the following link: http://digital.ni.com/public.nsf/allkb/41EB3AA9B4F9BE2D8625719D0051A2B0?OpenDocument.  Since my computer is new and the screen resolution is higher than the min I don't understand the problem?  I also turned on the auto hide the taskbar and changed my screen resolution to 1024x768 and it still gives me the error?  I don't understand why I can't run a program when my screen resolution is MORE than the min resolution?  Is this program that crippled that it can't work with a higher reslution?  Is there a work around I can use that will work.  As I said before, I am using the 64 bit version of Labview 2009 under Windows 7 if that helps.  Thank you.
Kevin
(4,683 Views)
Have you also tried closing the ms office toolbar?
(4,673 Views)
Thanks Muks.  I am not sure what the MS office toolbar is or how to turn it off?
(4,657 Views)
Accepted by kbaker
The windows magnifier tool is known to cause issues with the Vision Assistant.  Could you please ensure that this is turned off?  Instructions are linked here
Marti C
Applications Engineer
NI Medical
(4,650 Views)
Thanks Marti.  I finally found the problem.  I had the magnifier off, but the icon display needed to be at medium before it was on larger.  I am attaching a screenshot in case someone else has the problem.  Thanks again.
Kevin
(4,643 Views)
