Machine Vision
Display Geometric Curves
Hi!
I would like to create a Geometric Template, by LV, and I would like to display the "Edge Filter Size"-settings result on my image display, like in Template Editor.
(Fine - The edges are smooth) But I don't know how to do that.
+++ In God we believe, in Trance we Trust +++
[Hungary]
(4,042 Views)
I think i am not getting it clearly. Do you want to display in the image the text displaying edge detecction information? If not then which edge filter size are you talking about?
(4,040 Views)
Oh, man! I made a mistake! My question is the following.
I would like to create Golden Templates, without TE, using only LV. So, I read the manuals and When I want to use in golden Compare Template Vi's parameter : "Edge Thickness to Ignore", I have to set the mask on my template image. But I don't know how to do this. In Template Editor, it finds and sets the edges automatic. so This parameter of Golden Compare Template is usable.
Could you help me how to do this in LV?
Sorry for my fault!!!
[Hungary]
(4,015 Views)
Accepted by D60
If I get it right then you can very well create a template using vision assistant and generate lv code too.
(4,013 Views)
