Machine Vision
Distorted Camera Output
The  Basler acA2500-14gc is a GigE Vision camera, not 1394. You don't need any 1394 interface for this camera.
Message 31 of 45
(3,918 Views)
But it was under the IEEE 1394 devices list at desktop computer.
Message 32 of 45
(3,914 Views)
I assure you it is not. There is no PnP driver for a GigE Vision camera, since it is not on a PnP bus. If you post a screenshot it might be easier to explain what you are seeing.
Message 33 of 45
(3,913 Views)
Hello BlueCheese I've installed Basler cam's own software named Pylon Viewer. Helps to grab frame and snapshots and make adjustment of cameras some parameters. Normally I've got frames with it and there is no problem but hree times I've got bluescreen when I try to get frrames with that program. I don't is this and my problem related. After that installation cam2 source appeared. Named Basler Genicam Source. ( http://forums.ni.com/ni/attachments/ni/200/41983/1/nimaxscreenshot.jpg ) Maybe the thing under IEEE 1394 device is about this. Unfortunately I don't have access to laboratory right now. When I go there I will upload a screenshot.
Message 34 of 45
(3,908 Views)
Hi BlueCheese you were right. When I uninstalled Basler's software, Basler Pylon device in IEEE 1394 devices section, was removed. In NI MAX, cam2 source Basler Genicam Source was removed too. Only Basler acA2500-14gv  remained and I can grab frames at NI MAX with that desktop. But with my laptop, I still get that error attached below.
Message 35 of 45
(3,898 Views)
Sorry for flood post, I can not edit my other post. In addition my ethernet adapter is Qualcomm Atheros AR8171/8175 PCI-E Gigabit Ethernet Controlller(NDIS 6.20). Is there any problem with my ethernet adapter?
Message 36 of 45
(3,897 Views)
If you set the packet size to 1500 and still have the issue, it points to a firewall problem. If it fixes it, then you have a jumbo frames problem.
Message 37 of 45
(3,887 Views)
I am going to lose my mind. When I enable firewall, it gives Packet Size error, when I disable firewall, enable Jumbo Frames and decrease packet size to 1500  it gives Time Out Error.
Message 38 of 45
(3,873 Views)
Hi Butterworh,
Here is a resource which may help. It goes over possible reasons for the time out error:
http://digital.ni.com/public.nsf/allkb/17A956942535A2C786257419007778FF
Paolo F.
Message 39 of 45
(3,865 Views)
@FuManWho wrote:
Hi Butterworh,
I also tried this but still I get Time Out Error when I turned firewall off, when I turned it on(and adjust packet size) I get Packet Size Error. Is it something with Win7? When I purchased this laptop, ıt has got Win8 installed on it. I installed a SSD and changed my OS with Win7.
Message 40 of 45
(3,854 Views)
