Machine Vision
Distorted Camera Output
Hi Buttersworth,
One step that works sometimes is to go into your windows firewall in Control Panel and then go to advanced settings. I would create a new inbound  rule, by right-clicking inbound rules and selecting New Rule. In the following menu I would choose Port and then hit next. Then I would choose UDP and All llocal ports and then hit next. Then I would choose Allow the Connection and Next.In the next menu leave it all selected and hit next. Then name it as you want and hit finish. I would do this for outbound rules as well. This makes sure that we are allowed access through the windows firewall. Even if it is off, there may be some interference by windows firewall.
Paolo F.
Message 41 of 45
(3,144 Views)
@FuManWho wrote:
Hi Buttersworth,
Hello Fu.
I think I am the 1st person who did not find an appropriate solution for this GigE problem. I exactly did you what you said about adding Inbound/Outbound Ports. But nothing has changed. Still "Time Out Error". But this time when I activate Firewall, I don't get "Packet Size Error". I only get "Time Out Error" independent of Firewall's activity. I think we've made some progress (:
Do I need to make some adjustments at those options?(max.jpg)
Message 42 of 45
(3,135 Views)
Hi Butterworth,
First I would try to increase the timeout. It seems you have already done this, but this is a good step to try. Another thing we can try to do is to reset your camera file. To do this you will need to unplug your camera and then create copies of your camera files (.icd). After that move the copies to a different folder and delet the ones in the current folder. Afterwards plug your camera back and check the folder to see if a new camera file populates. Once it has try to select the camera file in NI MAX and try to acquire. The location of your camera can be found in a folder similar to:
C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Data
Paolo F.
Message 43 of 45
(3,115 Views)
@FuManWho wrote:
Hi Butterworth,
I've already done this but It could not help.
Message 44 of 45
(3,088 Views)
Do you have it configured for an external trigger? That would cause a timeout. Have you tried to lower the packet size to something much smaller? Have you tried enabling resends?
Jeremy P.
Message 45 of 45
(3,076 Views)
