Machine Vision
Distorted,disjointed images
I am using an AVT Stingray F201C (1394b) camera, and most of the images that I grab or snap are distorted. The images appear to be sliced and then spliced badly. I have attached an example of a snap of graph paper.
What would cause this? And more importantly, how do I fix or prevent it?
I am using C# for my application, but it also happens in MAX.
Image size and format and capture rate seems to play a role, but it happens in all cases.
Thanks!
Ryan
(3,174 Views)
Ryan,
This type of distortion generally happens with Firewire cameras when packets are lost. It could be due to various things such as a bad cable, poor quality 1394 adapter/chipset, or your system's PCI/memory bus being saturated (the common 1394 chipsets have very little onboard buffering).
Eric
(3,161 Views)
