Machine Vision
Help Creating ROI on central line
Hi -
I'm having a bit of a problem using the IMAQ ROIProfile VI.
I'm currently working on a project where I need to extract the profile of center line of an image. I was able to do this when I set the ROI Profile to controle HOWEVER I want to do this programatically. I already have the coordinates of the line I just need to figure out how to unbundle the ROI Descriptor to manipulate just the coordinate array
Any Sugestions?
Bruno Noronha
Certified LabVIEW Associate Developer
Using LabVIEW 8.6
(3,676 Views)
Accepted by topic author bnoronha
Something like that:
Otherwise you can use IMAQ Convert Line To ROI - probably its will be more easy for you.
Andrey.
(3,674 Views)
the IMAQ Line to ROI worked perfectly!!!!
Thanks a million!!!!
Bruno Noronha
Using LabVIEW 8.6
(3,670 Views)
