Machine Vision
Do I need a software download?
Hi
Pretty new to LABView.
Just wondering if I need to first download software to enable video acquistion on LABView 2013?
(5,073 Views)
To do image acquisition you will first need to install LabVIEW 2013 and then the NI Vision Acquisition Software which is a driver for acquiring, displaying, logging, and monitoring images from camera devices connected to your machine.
To actually do Image Processing and/or work Machine Vision-related applications you will also need the NI Vision Development Module for LabVIEW which holds all the functionality. You can download the evaluation version here https://www.ni.com/en/shop/data-acquisition-and-control/add-ons-for-data-acquisition-and-control/wha...
Depending on how much experience you have with LabVIEW in general you might be interested in the basic functionality described on the following page: https://learn.ni.com/learn/article/labview-tutorial  .To get started quickly with vision you can explore some of the examples on the following page: https://www.ni.com/en/shop/data-acquisition-and-control/add-ons-for-data-acquisition-and-control/wha... and also check the user manual here : https://www.ni.com/docs/en-US/bundle/371007b/resource/371007b.pdf
It might also be worth checking out the community examples here for some more vision examples: https://forums.ni.com/t5/Community-Documents/tkb-p/3044
Hopefully this will help kickstart your vision developments. Best of luck!!
______________________________________________________
Mark N
National Instruments UK & Ireland
(5,041 Views)
Thanks, this was very helpful.
(5,035 Views)
