Machine Vision
IMAQdx problem with FireWire camera
I have some problem with IMAQdx. To my app, I use a FireWire 1394 camera with LabVIEW 2012, NI MAX 5.5 and Win7.
I capture images to be analysed it. My problem is the following : the application runs without problems (Open imaqdx session, GetImage, Close session…) but completly random, the vision does not longer work and displays the error message « No acquisition in progress » while communication is always open. And without change anything in my vision configuration… After this error, I leave the app to display an image in NI MAX. But I can’t show my image because the acquisition speed is itself amended (400Mbp to 100 Mbp). I try to fix it with a property node, but is it no more editable. When I unplug the device and plug it back, it still ok. I have some images…
Have someone a solution to my problem ? I found on the net that is a 1394 driver problem with Windows, but I don’t have found THE solution…
I posted on the french forum without solution.
Thank you in advance.
Meilleures salutations.
LV2012
Message 1 of 16
(7,728 Views)
Hi Gum51,
can you attach your VI to see how it is programmed?
You told "I found on the net that is a 1394 driver problem with Windows, but I don’t have found THE solution."
Which link is this information located?
You use a FireWire 1394 camera (which one?) with LabVIEW 2012, NI MAX 5.5 and Win7 (in 64- or 32-bits?).
Which IMAQdx version do you use?
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
Message 2 of 16
(7,704 Views)
Hi Suse,
Thanks to your answer, but I can't post my VI... To explain, I have a Init Part at the begining of my program (cfg files, paths, com, etc...). And take an image with a syncronous loop. At the end, I close all the communications. In my operating part, I take an image with "IMAQdx GetImage.vi" and display it to the FP.
I use a ImageSourcing DMK31AF03, win 32. I don't found the IMAQdx version...
All that I have found on the net for this problem, is to update my camera driver. And all my drivers are updated...
Thanks a lot!
Best regards
LV2012
Message 3 of 16
(7,692 Views)
for your ImageSourcing DMK31AF03 which is a FireWire-camera, you find some informaiton here:
What is a Camera File, Do I Need One, and How Can I Obtain One?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YI74CAG&l=en-US
Where Do I Place My Camera File Once I Download It?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6ywSAC&l=en-US
Here you find the Imaging Source DMx 31AF03 Compatibility Report.htm
Driver Version NI-IMAQdx 3.1.1f0
You use the functions from ImageSourcing?:
http://www.theimagingsource.com/de_DE/products/cameras/firewire-ccd-mono/dmk31af03/
If this doesn't work, please call the vendor.
Best regards
Suse
Message 4 of 16
(7,687 Views)
Here you see which LabVIEW version to use:
NI-IMAQ, NI-IMAQdx, NI-IMAQ I/O, and VAS Compatibility with Different LabVIEW Versions:
https://www.ni.com/en/support/documentation/compatibility/17/vision-acquisition-software-and-labview...
Windows Version Compatibility with LabVIEW:
https://www.ni.com/en/support/documentation/compatibility/17/labview-and-microsoft-windows-compatibi...
Best
Suse
Message 5 of 16
(7,684 Views)
Thank you Suse for your links!
I use some personal libraries (with ground IMAQdx functions) but they are compatible.
All my labview versions are compatible...
I have some pictures but sometimes (4-5 times during a day), I have this problem. With a incompatibility that should never operate... (?)
Best regards
LV2012
Message 6 of 16
(7,679 Views)
What versions do you use? Can you create a MAX-report?
1. Start -> Programs -> National Instruments -> open Measurement & Automation
2. File -> create protocol -> choose technical support and my system -> next -> next -> choose path -> next -> finish.
Do you use the functions from ImageSourcing?:
It's with IMAQdx too.
Best regards
Suse
Message 7 of 16
(7,677 Views)
No, I only use my own libraries.
You see in attachment my MAX-report.
LV2012
Message 8 of 16
(7,672 Views)
Maybe it's a Firewall issue:
Configuring LabVIEW, LabVIEW DSC and Lookout to Work With the Windows Firewall
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIKqCAO&l=en-US
What Ports Do I Need to Open on My Firewall for National Instruments Software Products?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kH68SAE&l=en-US
Message 9 of 16
(7,670 Views)
Do you get an error message? Can you make a screenshot of it?
Message 10 of 16
(7,668 Views)
