Machine Vision
Do I trigger the camera or the frame grabber?
Hello :mansurprised:
I have an analog camera (Electrophysics model 7290A) and a frame grabber (NI PCI-1405).
I also have a pulse power supply with a laser connected to it.
What I want to do is trigger the camera in a way that it will take pictures synchronised with the pulse power supply.
Now, both the frame grabber (trig) and the camera (genlock in) have trigger inputs. Which trigger input do I use?
I am programming in Labview 8.6, do I need somekind of timing code to make sure the code is not slower then the trigger pulse?
If I lose some frames due to slow code, that is ok. But I need somekind of synchronisation, right?
I am using IMAQ Vision and I made sure the trigger signal from the power supply is compatible with both the camera en the frame grabber trigger input.
Hope you guys can help me!
Sincerely,
Heinen
The Enrichment Center is required to remind you that you will be baked, and then there will be cake.
(3,307 Views)
Hi, you are right. You have to trigger both the camera and the frame grabber.
Marco Brauner NIG
(3,285 Views)
