Machine Vision
Does NI Vison have some function about image stitching?
Hi,everybody!Does NI Vison have some function about image stitching? It's best you show me some examples.The Images  have been snapped by three cameras.  Best Regards!
Striving is without limit!
(3,198 Views)
I have stitched two threads below together 🙂
https://forums.ni.com/t5/Archive-TKB/Stitch-Multiple-Images-Together-in-LabVIEW-with-Vision/ta-p/353...
https://forums.ni.com/t5/Example-Code/Image-Stitching-a-Video-Stream/ta-p/3996144
-AK2DM
(3,176 Views)
The answer is yes because I am doing this frequently. Use the IMAQ ImageToImage 2  function. You need to create a large image first. Size it and copy sub-images into this with the appropriate offsets.
Regards
Simon
(3,138 Views)
Simply pasting images next to each other is quite easy, as described.  If you are trying to match image details and combine them into a single seamless image, the tools are not there.  That requires tools for matching details, distorting the images, and merging the images.  I use a program that came with my camera (Canon) to do things like that.  I am not aware of tools to do this automatically.
Bruce
Bruce Ammons
Ammons Engineering
(3,132 Views)
