Machine Vision
VBAI 2014 FTP DATA Logging (don't want in separate file)
Can anyone help me on this one issue?
I am using VBAI 2014 to acquire, process, and save pictures data through FTP server.
So when I use Data logging function when acquired multiple images, it connected FTP perfectly and it only can save one image (the first image data) instead of multiple image data.
One more thing is I can't choose file name other than user-defined. Don't know why, is this matters the data logging part?
Can anyone help me to solve this problem?
(2,885 Views)
If you are trying to save images, you might want to try Image Logging:
You say you do not want separate file.  What are you looking to log?  Data or images?  If data, then data logging should be fine.  Are you sure you are actually running through multiple images and not just a single picture?
(2,811 Views)
Hi kelle,
Everytime run one image, but I want the data saved in one txt file.  So I have both image logging and data logging. But every time I run loop it will save every image (which I want) and separate data file (which I want them all in one file).
Does this make sense to you?
Rex
(2,746 Views)
