Machine Vision
Does anyone know how to create coordinate system using Particle analysis in Vision Development Module?
Hi All,
I am developing a VI for visual inspection of a product. The product under inspection is not positioned in the camera field of view consistently enough to use fixed search areas. So I have to inspect based on a Coordinate system. When I searched for the solution I found 3 different methods.
1. Finding the edges
2. Finding Pattern
3. Particle analysis
I am unable to use the 1st method because I don't have any reliable edges on the product.
The second method also is not possible because the pattern which is available as reference is a circle. It can create orientation issues.
I think the third method may work because I have two circular objects which can be used as reference.
I have got idea how to use the first 2 methods. Can anyone help me with the third method?
Into the pursuit...
Maverick
(3,499 Views)
Hi Maverick,
Fixing co-ordinate system with particle analysis (one method) can be done by finding centroid of the particle (x and y locations), with reference from these locations you can fix the coordinate system.
Post your image so that will guide you easily..
Silver_Shaper | CLD
(3,493 Views)
Thank you for your reply.
I am trying with "Pattern matching" method for creating coordinate system. Fortunately it is working fine for me till now. I will come back if this method fails.
Into the pursuit...
Maverick
(3,488 Views)
