Home
Community
Discussion Forums
Most Active Hardware Boards
Machine Vision
Topic
Machine Vision
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Does anyone know if there's a way to change the property node or user LUT while in a LL Grab process?
Aaditya
Member
05-16-2001
10:35 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I need to modify the LUT and reorient the acquisition window, but have only been able to do it between LL Snap processes. Is there a way to do it within a LL Grab process so that i do not need to manually refresh by multiple snaps?
-Thanks
Aaditya
0
Kudos
Message
1
of 2
(3,349 Views)
Reply
Re: Does anyone know if there's a way to change the property node or user LUT while in a LL Grab process?
MatthewSmith
Member
05-24-2001
02:38 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Aaditya,
No, you cannot change the LUT programmatically during a LL Grab. Any changes to the LUT must occur before calling IMAQ Start.vi.
Matthew Smith
Applications Engineering
Kudos
Message
2
of 2
(3,349 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
