Machine Vision
Does anyone know if there's a way to change the property node or user LUT while in a LL Grab process?
I need to modify the LUT and reorient the acquisition window, but have only been able to do it between LL Snap processes. Is there a way to do it within a LL Grab process so that i do not need to manually refresh by multiple snaps?
-Thanks
Aaditya
(3,344 Views)
Aaditya,
No, you cannot change the LUT programmatically during a LL Grab. Any changes to the LUT must occur before calling IMAQ Start.vi.
Matthew Smith
Applications Engineering
(3,344 Views)
