Machine Vision
Doesn't 64bit version NI-IMAQ library exist?
I use PCIe-1429 and NI-IMAQ 4.1, and programming on VS2005.
(4,551 Views)
Yes, IMAQ includes 64-bit application support for a C/C++ development environment. The sample projects included for Visual Studio should have a configuration for "x64" targets that you can see.
Eric
(4,530 Views)
Thanks for answer.
But, I can't find it...
Do you know exact (or typical) path?
(4,522 Views)
Accepted by wooddoll
Wooddoll,
The 64-bit import libraries typically are installed under C:\Program Files (x86)\National Instruments\Shared\ExternalCompilerSupport\C\Lib64\MSVC\imaq.lib for the 64-bit variants.
The actual 64-bit DLL is typically installed to C:\windows\system32\imaq.dll.
Eric
(4,513 Views)
Thanks, Eric.
I found it, and it works perfectly. 🙂
Have a nice day~
(4,509 Views)
