Machine Vision
Double click event on a specific part of a Display Image
Hello to all.
First of all thanks a lot for reading this post and being able to help.
I would like to catch a doble click event on a Display Image.
The poblem is that I do not want to catch it if user has clicked on "Image Area" of Display Image, I want to catch it only if user has clicked on the edge of Display Image . Is there any way of knowing where in the Display Image has been clicked the user?
Thanks a lot!!
(4,649 Views)
First of all understand how forum works.
-You should make your question solved and mark solution once solved.
http://forums.ni.com/t5/LabVIEW/Double-click-mouse-event-to-change-display-size/m-p/3325556#M975216
-You should provide code or snippet what you tried and didn't work.https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2PkCAI&l=en-US
uday
(4,634 Views)
ok sorry.
Any help?
(4,627 Views)
You have to be creative to make things work..!
For double click event I know you got the solution and for image border doublke click ..you can put a transparent 'Flat Box in Decoration' to disable region for click..!
Make sure to attach your efforts next time.!
(4,623 Views)
Thanks a lot for replying.
I think it does not work for me because I need to do zoom in image area so if I put a transparent Flat Box in image area I won't be able to do zoom...
(4,618 Views)
Accepted by A.Salcedo
In the event, you can get the coordinates of mouse click and if it is not inside your image area you can catch it.
uday
(4,613 Views)
Thanks a lot, it can work!
(4,611 Views)
