Machine Vision
Edge Strength Profile
I am using the imaqFindEdge function to do edge detection in my own C application. I need to provide the ability to control the threshold, width and steepness settings from the application's user interface. I would like to display an edge strength profile like that in the NI Vision Assistant Find Straight Edge Setup so that the user of the application can see a visual representation of the settings. I can display a line profile but I am having trouble figuring out how to obtain the edge strength profile. I tried using imaqEdgeTool2 but that only returns the edges that break the threshold, not the entire profile. Any suggestions would be greatly appreciated.
Thanks.
(4,724 Views)
Hello Andrew,
Thank you for using our discussion forums. You can use the function, "imaqROIProfile" to get the profile information along the line. If you are using LabWindows/CVI there is a shipping example that is included with NI-IMAQ that shows this process. Please refer to the Edge Detection example installed under the ..\National Instruments\CVI70\samples\Vision\2. Functions\Caliper folder. I hope this helps you out. Have a great day!
Nipun M
Applications Engineer
(4,708 Views)
Hi Nipun,
Thanks for getting back to me. "imaqROIProfile" returns the same information as imaqLineProfile, but enables you to use any path. Applying this function to a straight line yields the same result as imaqLineProfile. I am trying to graph the edge strength profile, not just the profile of the pixels along the line/path. I'm trying to figure out how to convert this type of profile to an edge strength profile as I haven't been able to find an IMAQ function that returns this information.
Andrew
(4,706 Views)
dear Andrew
I am having the same problem in getting the data out of edge strength profile (ie to export it to a spreadsheet) etc. Have you found a method to do this?
Alex
(4,499 Views)
Hello Alex,
Thank you for contacting National Instruments.  There is a knowledgebase (KB) entry that talks about this.  Here is the link:
Mike T
(4,467 Views)
