Machine Vision
Edge detection of a video using webcams
Hi Guys!!
 I'm currently doing a project and I have to do the following:
-> apply edge detection to a video that i am acquiring from a webcam
and i dont know how to go about doing it so if any of you guys have an idea i would greatly appreciate it.
I can use the webcam and save the video, but now I would like detect the edges of a video acquiring up to ten images per second.
Thanks in advance for your time and your help 🙂
(3,836 Views)
What is the video format?Avi?
(3,820 Views)
Yep its .avi 🙂
(3,814 Views)
See the attached example and insert the usb capture
(3,812 Views)
Hello Cleopatra,
Can I ask what it is that you are recording with your camera as this will affect the method you use to search for the line detection.
With regards,
Philip
Philip
UK Branch
===If this fixes your problem, mark as solution!===
(3,748 Views)
