Machine Vision
Eliminate Effects of Dirt in VBAI OCR
Good day again NI Experts,
I would like to seek help about improving the VBAI's OCR character recognition. In my application, some dust/dirt manages to slip into an IC where I need to get the data through OCR. That's when my problem occurs. In one of my example where texts read "706MMG122", a dirt slips between "1" and "2" and touches "1" (please refer to the image). When I apply an OCR ROI, OCR can't separate "1" from "2" although "2" is separated from "1" and the dirt, as shown in "OCR_ROI_1,2_mod2".
In the next example where texts read "DCTQD", a dirt slips between and above "D" and "C". When I apply an OCR ROI, OCR can't separate the dirt from "C" although the dust is far above it. For some reason, I can't minimize the size of the ROI. Please advise me on how to deal with these dot-like dusts and its effects.
Thank you very much,
Andrei K.
(3,103 Views)
DCTQD's OCR ROI
(3,091 Views)
Something that might help is to specify the min width, height, and size for characters to help keep characters from getting joined together. See the attached screenshot for a sample. To avoid having the 1 and 2 combined, the min width also prevented to the full M from being read, but I would bet with the amount of the M being used, it would still work alright.
Hope this helps,
Brad
(3,073 Views)
