Machine Vision
Enhancing USB Camera Image Resolution in LabVIEW
I used imaqdx on another computer today running labview 2011, and the webcam works! I was able to acquire an image at 2.0M pixel; the only problem is the webcam is cheap and doesn't have auto focus, now I need to find another usb webcam, any suggestions ??
Message 11 of 23
(3,105 Views)
Hi 7ayoriader,
I'm glad you got it working! You can go to our Industrial Camera Advisor page and see a list of supported cameras. Hope this helps!
Mychal F
Message 12 of 23
(3,091 Views)
On the subject of camera focus, I was wondering if it is possible to adjust this from within Labview? Preferably, I would like to have a focus slider bar that I can adjust from the front panel of my VI. Can this happen?
Message 13 of 23
(3,066 Views)
Dear brjohns
However this is not programmability possible with normal lenses of the camera, there are certain lenses available in the market with motorized zoom and focus. You can do with this.
Silver_Shaper | CLD
Message 14 of 23
(3,057 Views)
Hi Sazi,
Thank you for the response. I do believe my camera has motorized focus, because there is a focus slider bar included within the software that came with the camera. This is what makes me believe that I could potentially program this into Labview. The problem is that I have no idea how to go about this.
If this cannot be achieved, I guess I will have to try and "trick" the camera into focusing how I want it to.
Message 15 of 23
(3,038 Views)
Many USB webcameras with internal lenses have a built-in focus that can be accessed programatically. Moreover, DirectShow has a specific interface for this that IMAQdx supports. It would be up to the camera vendor to ensure that they have implemented the proper DirectShow interface for this to be accessible via IMAQdx.
Eric
Message 16 of 23
(3,031 Views)
Thanks Eric! I will look into this and post what I find out.
Message 17 of 23
(3,022 Views)
hi brjohns,
I got the same problem as yours. My USB camera has a resolution of 1024x768. I tried with NI-IMAQdx (Labview 2010) but I could not get the full resolution.
Could you show your solution in detail?
Thanks in advance!
nhoang.
Message 18 of 23
(3,013 Views)
I have attached my camera VI file. Hope this helps.
Message 19 of 23
(2,997 Views)
thank brjohns,
I have tried your program with my USB camera, but the problem still exists.
the reason may be the camera driver. It is not fully compliant with Direct Show.
Message 20 of 23
(2,987 Views)
