Machine Vision
How use your intergrated laptop webcam on LABVIEW
So I am having trouble acquiring an image from my intergrated webcam. LABVEW 2010 with VISION BUILDER AI, VISION ASSISTANT, the NI-IMAQdx for USB. I have access to mostly all software. I am current using a DELL XPS m1330. I believe the integrated camera is a CREATIVE LABS LAPTOP INTEGRATED WEBCAM.I have check the Measurement and Automation Explorer and the device is not in there. When I check my computer hardware under Device management(Note: not part of labview), I look under the Imaging Devices and my Intergrated Camera is installed. Should the Vision Assistant automatically detect my integrated camera. I have went hands on a LabView symposium several weeks ago and I was able to acquire an image from the intergrated web cam on thier laptop.ANY TIPS?? would help thanks....
Message 1 of 24
(15,545 Views)
Since you are talking about an integrated camera, the type of camera they had on  their computer is probably different from yours. So my initial reaction is that your camera might not be directshow compliant and that is why it is not recognized in MAX.
Message 2 of 24
(15,523 Views)
What do you mean by "NI-IMAQdx for USB"? Are you installing IMAQdx (and if so, what version?) or are you installing the old (unsupported) "IMAQ for USB"?
Eric
Message 3 of 24
(15,518 Views)
bump
Message 4 of 24
(14,919 Views)
Hi fmagno,
Can you tell me what you are having issues with? Are you having problems acquiring an image from your integrated laptop webcam? What kind of webcam are you using and is it direct show compliant?
Can you see your camera in Measurement & Automation Explorer (MAX) and how are you trying to acquire the image in LabVIEW? Thanks!
Mychal F
Message 5 of 24
(14,897 Views)
I am Very much intrested in Using Labview vision development module is it possible to use laptop integrated webcam in Labview. Please guide me as i was using it previously in MATLAB easily.
with best regards,
Gagandeep
Gagandeep sharma
Message 6 of 24
(14,354 Views)
Hi Gagandeep,
In order to acquire from a web camera you will first need Vision Acquisition Software. Ifyou have Vision Development Module you should be licensed for Vision Acquisition Software, you can download it from the link below. Next you will need to make sure your web camera is direct show compatible. Once you have the IMAQdx driver installed from the Vision Acquisition Software you should be able to see you camera within Measurement and Automation Explorer. After you can see the camera in Measurement and Automation Explorer you can start working with it in LabVIEW with the vision palette and examples.
NI Vision Acquisition Software 2011.09 - Windows 7 x86/XP/Vista/7 64 bit
http://joule.ni.com/nidu/cds/view/p/id/2625/lang/en
Vision Setup and Services
http://www.ni.com/vision/setup/
Tim O
Message 7 of 24
(14,341 Views)
Hi Tim O,
           I'm able to see my laptop camera detected by MAX and also able to take pictures using MAX but when i try to run Grab and Save to AVI.vi example program its throwing this "Error -1074397163 occurred at IMAQ Init.vi"  Pls help
Message 8 of 24
(14,314 Views)
Thanks Bro will try this thanks for Suggestion..
Goldy
Gagandeep sharma
Message 9 of 24
(14,305 Views)
Hi +918142355510,
This article discusses common errors, including the one you are seeing: http://digital.ni.com/public.nsf/allkb/3434173630CBC97686256F8000536593?OpenDocument. What interface name shows up for the webcam in MAX? Do you set the VI to the same interface name when running the example? If it works in MAX, you should be able to get it to work in LabVIEW because the same driver calls are being made.
Message 10 of 24
(14,289 Views)
