Machine Vision
How use your intergrated laptop webcam on LABVIEW
Hi Joeseph,
            Thanks for your reply i'm using the same interface name given by MAX, i've attached a image showing the error and the names in program and MAX pls inform if i'm going wrong anywhere.
Regards
Vishwas
Message 11 of 24
(3,315 Views)
Hi Vishwas,
The example you are using, "Grab and Save to AVI," is specific to IMAQ drivers. Your webcam can only function with the IMAQdx drivers, not IMAQ. This document outlines the difference between the two: http://digital.ni.com/public.nsf/allkb/4331B4AA3AE95233862574C200539A2F. In order to get your code working, please take a look at the LabVIEW examples under IMAQdx. It looks like someone has already written IMAQdx code that does what you want in this community example: https://decibel.ni.com/content/docs/DOC-3587.
Also, when you select a camera in MAX the camera resource becomes reserved, so if you try to access it in LabVIEW, you'll get an error. Once you have migrated to the IMAQdx drivers, make sure that MAX is closed, or the camera is not selected before you run the LabVIEW VI.
Message 12 of 24
(3,308 Views)
Hi  Joeseph,
        Thanks for your reply the program is working fine now,
Vishwas
Message 13 of 24
(3,296 Views)
Actually i am facing problem in interfacing my inspiron1545 dell integrated webcam with IMAQdx, I cant see my device in list. But one of my friend told if he is using USB external web cam it is visible in the list. Please guide for the integrated web cam what else i need to use my leaptop web cam. I am using Windows 7 32bit.
Gagandeep sharma
Message 14 of 24
(3,186 Views)
It is likely that your integrated webcam does not run on any of the protocols that is supported by IMAQdx.  Check out this article for which cameras are supported by NI's drivers.
Cole R.
Software Engineer
Message 15 of 24
(3,177 Views)
Sir but still hvnt get my answer can i work with integrated web cam in imaqdx
Gagandeep sharma
Message 16 of 24
(3,171 Views)
If you don't already see the camera in MAX it may be that the camera is not supported.  I can not say for sure so you will need to check if the camera follows one of the protocols supported by the IMAQdx driver.  In specific, I would check if the camera is DirectShow compatible.
Cole R.
Software Engineer
Message 17 of 24
(3,157 Views)
Ok sir.. Thanks for support i will be waiting
Gagandeep sharma
Message 18 of 24
(3,155 Views)
I won't be able to check for you since we do not have the camera model or vendor.  You will need to find that out and ask the vendor if the camera supports the protocol or if it uses a proprietary driver.
Cole R.
Software Engineer
Message 19 of 24
(3,139 Views)
Ok sir but camera model is 1.3mp creative labs
and drivers are working properly
Gagandeep sharma
Message 20 of 24
(3,135 Views)
