Machine Vision
How to validate Acquisition Window settings via C API?
I am controlling a Basler CameraLink camers connected to an NI PCIe-1429 framegrabber. I'm acquiring frames, settings ROIs etc just fine via the NI-IMAQ C API. However, I need to set the Acquisition Window programmatically and it appears the API does not validate the attributes I send it. Nor does there seem to be a straightforward way of validating this programmatically.
Here's what I do:
I use imgSetAttribute2() to define IMG_ATTR_ACQWINDOW_LEFT/TOP/WIDTH & HEIGHT.
It doesn't seem to matter what numbers I pass this function. If the values are valid (i.e. does not exceed the max resolution of the camera) all is well. If I use values, say width, that exceeds the camera resolution no error occurs.
When I use imgGetAttribute() on these attributes, I can retrieve also invalid values as set.
When I attempt to do anything else, like setting an ROI, it of course fails with the error:
"The requested acquisition window is invalid."
Now, I do see in MAX that it is capable of reading the max resolution of the camera (under the Acquisition Parameters tab).
So, my question is:
How can I programmatically read the maximum image size through NI-IMAQ? How does MAX do it?
Per
(4,988 Views)
Hi Peka,
I know that MAX accesses the properties of a camera through the camera files. The camera files are located in a folder similar to:
C:\Users\Public\Documents\National Instruments\NI-IMAQ\Data
You should be able to see certain attributes of your camera in these files.
Paolo F.
(4,946 Views)
