Machine Vision
labview can not detect my smart camera ,1774c
Hello.
I have a 1774c camera and a computer with Labview2012 with Vision Acquisition Software and Real Time module installed as well.
MAX detects my camera and allows me to grab video or snap pictures.
But when I try to create a Labview vi and use a example to learn,but  no camera is found.
Can anyone help me with this problem? If you need any more details just ask.
Thanks in advance!
(5,149 Views)
I believe you have to create a target in your project for the smart camera.  To LabVIEW, it is a separate computing device so it needs its own target.  Inside that target, everything should work fine.
Bruce
Bruce Ammons
Ammons Engineering
(5,121 Views)
Also make sure you dont have two sessions open at the same time
(5,092 Views)
