11-25-2013 10:08 AM
Hi there,
I'm using LV10 and my VI is supposed to read and analyse an avi video. On my Laptop everything is working fine. Now if I use it on another system Error 1074396009 occurs. It seems as if there might be some codec problem although the video can be played in VLC or WMP without any problems.
Does LV10 only support certain kinds of codecs or what's causing my problem?
And most impotantly, how do I solve my problem?
Kind regards,
seasoo
11-25-2013 04:07 PM
This is not a LabVIEW issue but more to do with the codecs that are installed in your system. I am not sure what version of NI-IMAQdx you are using, but you need to make sure that the right compression filter (pre-IMAQdx 4.7.2) or codec (post-IMAQdx 4.7.2) is being used to de-compress the AVI file.
Have a look at the following to figure out what compression filters or codecs are installed in your system:
Writing a Compressed AVI File with the IMAQ Vision Acquisition Software
Another good read:
AVI Codec Support with AVI2 in NI Vision Products
Make sure you have the right codec/compression filter installed and you should be good to go.
11-27-2013 06:41 AM
Alright, I tried to check my filters...
the machine that is working properly uses these filters:
another machine only works if I use avi files that use mjpeg compression. xvid and divx is not working. on this machine labview tells me these filters are available:
I got the feeling that LV2010 does not really know how to work with divx 6.9.2, am I right? Though I can't change the codecs on that machine, I'd like to know if upgrading this codec could help or do I have to remove it?
