Machine Vision
How to Install Inspection Step in Teststand 2013?
Hello
I try to install the NI Vision Builder Inspection Step to Teststand 2013. I Installed  NI Vision Builder Automated Inspection 3.6 and Ni Vision Acquisition Software 8.5.1 and I Installed from "ts_vbai_36_and_older_july10.zip" the inspection step to TS2013.(https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAZgSAO&l=en-US)
But when i try to run inspection step connect target i got an error message. (See screenshot)   I dont know what s wrong and how to solve!?
(5,671 Views)
The only way I can reproduce this error code is by specifying a different version than 3.6.0 in the "VBAI Version".  Tested in TestStand 2010 SP1 with VBAI 3.6.1.
(5,659 Views)
Any reason you're not using the new (came out in VBAI 2010) VBAI API as illustrated in this video to control VBAI from TestStand:
https://www.ni.com/en/shop/electronic-test-instrumentation/application-software-for-electronic-test-...
Just thought I'd point this out since a lot has changed since VBAI 3.6.
(5,637 Views)
I would recommend using a newer and well upgraded version of VBAI as Brad suggested
(5,610 Views)
Me too. (Regrettably I had to type it.  No "Me too" button here  Smiley Wink)
(5,607 Views)
