Machine Vision
Error -1074397038 occurred at IMAQ Start.vi for 64bit Labview 2011 SP1, Win7
I am using a MC1362 camera from Mikrotron with a PCIe1433 framegrabber. I was using it with windows XP, 32 bit, labview 2010 SP1 32 bit, it was working perfectly fine. I just switch to windows 7 with labview 2011 SP1 64bit, and it is not working anymore with my custom routine in labview, though it works with MAX and camera file generator and I use the same camera file.
When I run my routine, I have this error message:
Possible reason(s):
NI-IMAQ:  The requested serial termination string was not found in the returned buffer.
Then, If I try to run the camera with MAX, it doesn't work anymore, I have to reboot the camera, and put it in the right mode with the Mikrotron control tool to obtain an image.
I have seen similar issue on a Basler camera on the forum, and it has been solved by using a camera file to set the different parameters. There is no camera file complete to set all the parameters of the camera, so I had to program them in serial to drive the camera with my Labview routine.
Could you help me to solve this issue please?
Bests
David Dulin
(3,724 Views)
This forum post is already handled --> SR 1154262.
Kind regards,
Corné Westeneng
NI-Netherlands
(3,708 Views)
