Machine Vision
labview remote connection
I have installed Labview on my office computer, however my personal laptop is connected to the instrument of interest in the lab. I can not install Labview on my personal laptop because of university license policy. I installed the GPIB driver on my laptop. I wonder if I can use Labview to remotely connect to the laptop (known IP address) and collect data.
Thanks in advance
(3,387 Views)
Hi hn1,
Unfortunately, I don't think that connecting directly to the instrument over the network will be possible. There are a couple of options I can think of which might be possible as a workaround. Both are fairly complicated:
1. Create a new project with a VI which reads data from the GPIB instrument and writes the data to a file on a shared network drive. Then build the project into an executable. Install the LabVIEW Runtime engine on the laptop. Put the executable file on the laptop and run it. Then create a VI on the desktop which reads the data from the file and displays it.
2. Similar to the above, but instead of writing data to a shared network file, use VI Server to share the data over the network from the executable file on the laptop to the VI on the desktop.
Hope that helps!
Nathan S.
(3,371 Views)
