Machine Vision
Error 69006 invalid address
Hi community,
I always getting an error message (invalid address), when I try to connect a GigE camera in MAX (Measurement & Automation Explorer). The IP- addresses are correct. I don't know, which address could be meant.
Or is it a driver problem?
Since I try I try the software supplied with the camera, it works.
Thank you for your advice.
Message 1 of 9
(4,682 Views)
Which camera you are using ?
Silver_Shaper | CLD
Message 2 of 9
(4,676 Views)
It's an industrial camera from Matrix Vision - mvBlueCougar-X125aG.
Message 3 of 9
(4,673 Views)
yes you are right me too experianced a prblem like this with mvBlueCougar-x120aG. Its basically updated version of camera firmware. If am not wrong you have v1.3.36.0 am i right? . We are in the process of sorting this issue with matix vision germany. If got solution will intimate you.
Silver_Shaper | CLD
Message 4 of 9
(4,664 Views)
You're right. The firmware is 1.3.36.0.
I'll search for a new driver. If I don't find any driver, I'll contact MatrixVision for trouble Shooting.
Thank's a lot.
Message 5 of 9
(4,661 Views)
I've the solution. It's not a problem of the firmware or other drivers.
It is just a check and the packet size: I have "events disabled" and increased the packet size. That's all.
Message 6 of 9
(4,635 Views)
Dear effeff,
I am very sorry i can't get your points. Can you explain somewhat briefly.
Silver_Shaper | CLD
Message 7 of 9
(4,633 Views)
Dear SaC.
I've contacted Matrix Vision, but they said that there is no problem of the camera or driver. They couldn't help me, because the camera runs with the MV- Software.
So, I tried many settings in NI Software. The solution was, that I have to disable "Events" and in addition increase the size of packaging when sending the data.
Now it's running.
EffEff
Message 8 of 9
(4,603 Views)
Dear EffEff,
where is the box to enable or disable the event? In MAX?
Thanks in advance for your help!!
Peggy
Message 9 of 9
(4,504 Views)
