Machine Vision
VBAI - LabView interface error - "The selected inspection could not be loaded", "Inspection File Error"
I have been programming/interfacing VBAI2012 and LV2011 for two years already.
There is one very frustrating problem:
- Sometimes after changing some codes in VBAI, and I switch to Inspection Interface (by clicking File->Switch to Inspection Interface), there would be error saying "The selected inspection could not be loaded"
- and then there is NO WAY to know what is going on. It does not tell you where the error is. Its so frustrating, you changed a couple of things, and the you have error switching to Inspection Interface, but then you don't know what is causing the error.
Is there any log file which I can check?
Message 1 of 1
(3,494 Views)
